Profiles Will Not Display
For some reason, I cannot get my profile to display. It starts out like the first picture then i had to zoom in (a lot!) to get to the station range of my alignment as in picture 2. It use to show up with the entire proposed profile and ground line. if I hover over the alignment/plan element, it shows that the active profile is the same as the alignment. The TOPO ref. file is the active terrain model as well. I'm sure it's something simple to fix it.
  • Which specific version are you using? Is this happening with only one specific element, one specific file, or is it an issue in multiple files?
    Is there any chance that you have those levels turned off for that view? (I've seen stranger things...)
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Here is the solution to my issue above. When I was creating the horizontal and vertical alignments in the GEOM dgn file, I referenced a Mstn V8i file that include the all of the proposed design features/elements. When I selected the horizontal alignment then opened the profile view, the software was looking for that V8i reference file I had TURNED ON (which was probably located over China on a small unidentified planet in the eastern hemisphere somewhere)! I turned off the display of that reference file and...TA-DAAAH!! There was my profile! I figured it would be an easy fix. Thank you for your feedback!
  • Aha! Thank you for letting us know the fix.
    It makes sense, a reference element can't have an "active" profile because it's not in the "active" file. Good sleuthing!
    MaryB
Reply Children
