Has anyone been having issues with ORD Templates utilizing multiple switches?
Gary
Not me. What issues are you having specifically and what version of ORD are you using?
Steven,
We are using 2021 R1 (and R2) and have noticed that using more than 2 switches (null points controlled through parametric constraints that are in turn tied to display rules) in a corridor and a given template drop will simply not work. The same template methodology worked in SS10 just fine. Why is there a limitation on the number of switches that can be used now in ORD?
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
Eddie, that's odd. Would you mind sharing an ITL?
SwitchIssues.itl
I was aware of an issue with superelevation being applied that would conflict with triggers, but not specifically switches.
Eddie, perhaps that's it. I don't use the built-in superelevation tools and so can't say much about that. I didn't notice that there was an ITL attached to your post so I'll try that out.
However, your first post got me really worried because not being able to use more than two switches would really rock my world.
I made a dummy ITL (attached) that has four switch-controlled blob-like components.
I ran it down a dummy corridor with a dummy alignment and turned all four switches on at random stations. Fortunately, all four blob-like components turned on! Phew. I can sleep tonight.
Test123.itl
