How do delete triangles in a complex terrain created from merged surfaces. The survey processing rules has been deactivated. I click on edit model to get the edit terrain model, click on delete triangles. I click on the terrain and it says that it isn't an editable terrain. Why is it not editable?
Aaron,
Did you try deactivating rules for the complex terrain model within the OpenRoads Model Tab?
