Importing an OBS file into ORD
We are running ORD Connect.  GDOT required release.  Trying to bring an OBS file into an imperial unit Survey Foot DGN.  Points come in fine, and measure the correct distance.  However every time I import the OBS file, it imports as Meter  not foot.  So everything is off by a multiplier of 3.28 etc.  So what am I doing wrong?  Same thing happens if I attempt to bring in the RAW file.  Scales out of whack.  Would like to give my client the data, rather than just an XYZ file.
Thanks for any help you can give me.
Parents Reply Children
