How to use Minimum Transition Before/After Drop command,what 's the purpose of this command?
Thanks advance!
Edition:ORD 10.0
Hope someone can record the video and share it.
I have found it . this command is used to create a template transition like create edition command. No longer need to click the Create Gradient command separately. Hope it's helpful for you!
