Super is not being applied in one of my corridors. i can see it point control and the correct points are set. i can see the purple squares that indicate where it should be. i have deleted the points from point control, closed/opened the file and reapplied the super. same results. Has anyone seen this before? thanks for your help. Brian
V8i SS10
do you mind sharing your files and the ITL file so that we can take a look to see what is going on?
sooo....got up the next morning, opened the the file and the corridor processed......and the super was applied. The day before I had reprocessed multiple times, deleted the super point control, reapplied the super to the corridor with no results. I guess the corridor just needed a good nights rest.
