I am having issues with a file where I get this message when I attempt certain commands.
I started with a new file and as a test, I imported a DTM from InRoads. I was able to select that terrain element and activate the export to file command.
The DTM came from InRoads Survey. So next, I created a new fieldbook and then imported the FWD into the file.
At this point if try to export the terrain to LandXML, I get a dialog box telling me its unable to due to Mismatched Civil data found in the file.
Next, I tried undoing everything and now, I could no longer import a DTM with the same message.
Also, once this message begins to appear, if I try to use the heads-up toolbar on the terrain element to export to file, nothing happens. No message or dialog box. I have to use the Terrain Ribbon tab's Export to File to get the explanation.
As a last resort, I also tried removing the civil model and it told me there was nothing to remove.
But - I tried one more thing: I exited the file and restarted ORD and now, everything works. This is maddening.
Probably should be in the ORD forum.
Oops!
