i tried to display the horizontal name,but not displayed.why?
I hope someone can answer this problem.
edition:ORD 10.0
Hello Joe,
We have already logged defect Defect 1007844:[Corridors] Corridor Objects dialog does not show "Horizontal Name" against this issue as, if we select corridor handlers > open properties dialog box we could see Horizontal Name assigned to corridor as shown in the below snapshot.
Thank You,
Purva Lakde
Answer Verified By: Joe
tks Purva,corridor properties dialog can display horizontal name properly, but template drop properties dialog can't.I think it's a defect. I can't open the defect 1007844. can you send this link again or file?
Yes it's a Defect which we have already logged for Corridor Objects dialog does not show "Horizontal Name.
Thank you for your time.Purva.
I forgot one thing. two places can't display horizontal name. one is corridor objects. the other is template drop properties dislog.
