Hello All-
I am struggling with getting my Dynamic Cross Section Cells to scale properly. There seem to be so many places in which a cells scale can be adjusted which is confusing. What is the proper workflow to properly setup these cells in Element Templates? Does the Annotation Scale in the drawing affect the size of these cells as well as all of the settings within the Element Template? Which is the correct way to get these set correctly? I tried to copy the Bentley standard PROW, EROW xsec cell tags but that didn't work out like I had planned.
Initially my tags looked correct, then I synced the Element Template Library with the Master Library and they got extremely large.
