Hello All-
I accidentally set one of my Model Component Material Symbology for a Asphalt layer to have this weird lane striping to be associated with it. Any thoughts on how to change this back to a normal Asphalt Symbology? I tried updating the Civil Materials Pallet, no dice. A guy I work with once told me I was "just OK" with using ORD so any help here is very much appreciated =) Thanks All.
Matt:
You should just be able to check the properties and then change said properties to whatever you would like.
Mark
Thanks Mark, this helped. Always appreciate your excellent feedback and advice!
Thanks Matt. I certainly hope so and I definitely appreciate you out here as well! BTW, the dude that told you "just OK" has no idea of what you may be capable of in the near future. Forget those types of negative folks.
