I have configured a Managed Workspace for OpenRoads Designer in ProjectWise, using the UK standard dataset, however when opening a file using the assigned Workspace it is forcing the Copy Out of all files in the same folder.
I can't see any other variables in ORD that define the active directory, so out of ideas of what to further exclude.
Question is - how do we stop the force copy-out of these unrelated files?
Becky
Hi Becky,
You may need to also add some variables like "_DGNDIR", etc. that include the current DGN folder to your "Variables to be excluded from copy out".
If thats not it you can identify what variable it is by having a look in your datasource bms folder workspace subfolder for the latest generated cfg file and search through it for variables that include the DGN folder path.
Mark
