How do I go about raising or lowering a terrain in ORD? I have a terrain I've made from proposed track profiles, and I want to lower it to represent subgrade. I looked into exporting as an XML and then bringing it back in, but neither the export or import appeared to have a raise/lower option.
Hi Tyler,
Try creating a Delta Terrain using the "To Plane" option. This value represents the vertical adjustment value and keeps a live link back the the original.
Create Delta (bentley.com)
Mark
Try to create a terrain from elements and one of the following option:
- use "create clipped terrain" and use here the offset: Create Clipped Terrain Model (bentley.com), this option also keeps a live link to source dtm in the properties:
Matthias
