Is it possible to display Survey point decorators from a reference file into your working dgn file?
This would be helpful.
Cliff
I'm not sure why this doesn't work. It should be a no-brainer. Are we supposed to import points into each drawing?
I think the idea behind Bentley adding the decorators to survey data is the same as geometry rules that show editable information on elements in the active file (e.g. lengths, radii, etc). However, I can see this being useful for many reasons within the survey environment. I've added the idea to the Bentley OpenCivil Ideas Portal. Will update this post when that vote url becomes available!
colliersengineering.com
