Hello everyone. I am having an issue with Bentley OpenRoads Designer, and would like to ask for help/advice here.
I am currently working on a project using a slightly older version of ORD. I created plan view and profile view sheets as I usually do, using the Named Boundary to create it. Immediately after creating the sheets, I tried opening them, but for all of them, I get the following message:
"The data in this file is from a newer version of a Civil Product:OpenRoads Designer Update 9 (10.09.00.91)
This file cannot be edited with:OpenRoads Designer CONNECT Edition 2020 Release 3 (10.09.00.91)
Press OK to view the file ReadOnly.Press Cancel to close without opening the file."
This didn't make sense to me, as I had just created the sheets myself, so I didn't understand how I could have used a newer version of ORD to create the sheets. Additionally, the software version numbers given in the message were identical (though the specific name was different).
I decided to try an experiment. I created another plan view sheet (using a different alignment from a different reference), and set it to "Open Model". It created and automatically opened the sheet file, so I drew a line in the sheet, then saved it. I attempted to reopen the file, but I got the same message as before. I opened it as Read Only, and when it opened, I found that the line I had drawn was still in the sheet. So it seems that if I set it to open the sheet automatically after generating it, I can edit the sheet file. But if I close it and attempt to reopen it, it no longer works.
I can update the file version then edit the file using a newer version of ORD (10.10, I believe), but we have been instructed not to do this for compatibility reasons.
Additionally, in case it matters, we are using ProjectWise for this project.
Does anyone have any idea why this might be happening to the sheets I create? And does anyone have a solution to this issue?
If more information is needed, please let me know.
Matthew:
We finally got tired of certain conflicts which were being caused, and completely uninstalled (including all additional data found in c:/ProgramData and c:/Program Files) both versions of the software, and then reinstalled 2021 R1 ONLY. We are fortunate that our primary client has not formally made any requirements as to deliverables based upon any version of the product. The schema change incorporated within 2021 R1 certainly caused us to make many changes and upgrade many files, but it does seem to be relatively stable for us (on its own!). Since your agency is requiring a downgrade to the deliverables, I would suggest that you do the reverse of what we have done here.
Mark
Yes, sir. Cleaned out all of the above!
I would suggest that ORD 2020.3 and 2021.1 are using some shared resources from somewhere. That looks like a schema from the drainage and utilities side of ORD, but I could be wrong.
When you uninstalled did you clear out programdata, program files and the temp folder where preferences are stored.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
