Hi there,
I have turned on height contour labels in a triangulation I created. When I export them to Autocad .dwg the height labels disappear. Can anybody help me out with this one.
Stephen
The label is not written in the DGN therefore it is not exported to DWG. You must label contour using the labelling tool.
One good alternative is to create a scalable terrain model (Reality Modelling workflow). You can manage properties of the stm for contours interval and labelling. Then you extract contours using the stm edit menu.
Hi JP, The method that I use have more control over the position of the label and the direction of the flow. I use the Label Terrain Contours tool.
It is a bit tricky to always get the text in the correct direction. Once to et use to the tool it is quick to label the contours.
Step 1
Text Style with Spacing Upside Down
Step 2
Create new Dimension Style and select Text style.
Senior Highway Design
ZUTARI SOUTH AFRICA & AURECON
