I am new to openroads desginer. I have been working with Inroads SS10 and SS2 earlier.
A variation i noticed in ORD , point control start and end chainages do not add additional drop points to the corridor. Key stations have to be added.
I am stuck with Linear template. There is no option to add additional point / Key stations. Due to template not dropped at the point control start end locations the model does not look complete. Gaps are formed.
How do i add key stations to Linear template or add Event point to the alignment.
I am using Openroads 2020 release 2
Thanks in advance.
Thnak you.
I am working in Openroads 2020 release 2 as project demands.
The add key station tool does not crash but gives message "invalid geometry"
With version 10.10.01.03 in Spanish it does not work
I am using OpenRoads 2021 10.10.01.03 and adding a Key station to a linear template does not work for me either.
error: Exception logged...
I am also having this issue with the same version...has anyone actually answered this or is it still a bug?
This appears to still be a bug. As Josue Candelario commented, I'm using OpenRoads 2021 10.10.01.03 and get error: Exception Logged..
