Openroads Designer 2020 R2 crashes instantaneously after opening geometry connector tool. I'm able to use geometry connector tool with2021 R1.
Hi Snehasish,
Does this happen on all the projects or project in particular? I am unable to reproduce the issue in the latest build of OpenRoads Designer (2021 R1). Sounds like a defect to me which is fixed in the latest built.
Amita Shinde
Thanks for your response. I could not find the problem in 2021 R1. But as the project is done in 2020 R2, I am looking for a solution in the same version.
