Scaled Length vs Unified Length, 3D length-Drainage
For ORD Drainage design, what is the difference between Scaled length vs 3D and Unified length? Which length value is being utilized to compute the system results?
  • There's some history in these settings. Once upon a time, your drainage layout might not have used accurate coordinates for the positions of nodes - it might have been more of a schematic representation. In that case, you needed to be able to set the length of a conduit - hence the "Has User Defined Length" property. You could set this to true, and type in a length. Therefore you have two properties that define the length, because it can be either User Defined, or the distance between the two nodes, which is known as the Scaled Length.
    You wouldn't want to have to keep track of which one was being used for annotation, so the Length (Unified) property always tells you the length that is being used in the calculations. This is the "centre to centre" length between the two nodes.
    Length (Construction) is the "clipped" length of the conduit, between the connection points at the nodes (often the inner faces of the walls of the nodes) so this is the length of conduit that will be constructed.
    The User Defined Length may also come in useful in the case where you are doing an unsteady-state analysis, with very short conduits. These can be unstable, but that's a different topic.
  • Thanks for the response! In some cases, my unified length and scaled length are slightly different by about a hundredth. What is the difference between these two values. Should they be equal?
  • I did a quick test in 2021 Release 2, and my unified and scaled lengths were exactly the same. You say "In some cases" so I guess your lengths are sometimes the same too. There are some settings for Pipe Length in Tools > Options > Drainage, that you might want to check:
  • How do we get the calcs to use the Construction Slope (as opposed to the Calculated Slope)?  Here's my need:  to be able to have the calcs be consistent with callouts (client wants Construction Length and Construction Slope called out on the plans and the calcs to be consistent with them).
    I believe the calcs are based on Unified Length (the field says it's the "active length depending on local and global settings".  Are the settings only "Has User Defined Length"?  Or are there others like, say, "Unified Length is Construction Length".  Maybe a Unified Slope for the same reason as Unified Length?
