Unable to generate any reports (volume reports, geometry reports) after updating to Openroads Designer CE 2021 release 2 version. All the reports are appearing blank.
This forum is for Licensing, Cloud and Web Services discussion and you may not get any answer to your question here.
Please move your post to the right forum - to do that, click "More" above the post, select "Move", delete the Licensing, Cloud and Web Services Forum and select OpenRoads Designer forum.
Have you recently upgraded from a much earlier release? Some new settings via CFG variables were added to allow reports to function in a PW environment. You may need to review those to see if they are causing the reports to be non functional.
I have updated to 2021 R2 and reports are working fine for me. I am using a shared workspace on projectwise. Sounds like an issue with your workspace.
Ross
