Hello
I have a problem with the annotation of crosssections. I have created the corridor and the collection file for crosssection production in 2021 R1. Annotating in this version, I had a problem with slope annotations. Some annotations were appeared to be in a location where no feature is visible. Switching to the 2021 R2, the problem persists. Now I annotate features in a location that has not been presented either to the corridor or to the cross-section I annotate. I tried many options, including workspace change or preparing a new annotation group. No Succes till now. Any similar experiences? Any idea or workflow to solve this situation?
Best
Hi, I just have a note that I discovered the same problem.
Hi guys,
We have just discovered an issue in ORD 2021 Release 2 where it is annotating the invisible/voided segments of 3d linear features that have gaps in them (created by template display rules, corridor clipping or alternating template drops).
As we have been unable to find a solution/workaround we've had to unfortunately go back to 2021 R1.
Mark
Indeed, testing produced the same situation...
Yes seeing the same... I hope they fix this soon...
Ross
We are seeing the same thing here. Seems to have got worse.
