For a project we need Reports from data out of Item Types / Items. The dgn file is part of a project that exist of multiple 2D / 3D dgn files that find it origin in OpenRoads Desiggner. The Item types are linked to an Excel file wich are linked to Feature Definitions.
This works all as suspected and the possibility to enrich objects with data from Excel, do calculations with it, is seen as added value.
If Reports are created however, thing are going wrong. If a New Report Definition is Created, the computer hangs for 65 seconds (see image below). In MicroStation CE u16 however, this works direct (the reports in the image below where made in MicroStation because ORD was unworkable slow).
Is it possible to generate Reports with no waiting time like in MicroStation / what am I doing wrong?
p.s. When testing this with a more simple file (see image below), no data is shown when Selected is chosen if a new Report Definition is created..
Hi Louis
I have the same experience, selecting a report definition takes a lot of time. This is independent of whether you use item types or any other method. I don't know if it's even slower than with R1, I now have a new computer with (a clean install of) ORD2021R2.
A small test: a design of a stretch of highway of approx. 1 km with a bridge and a connection, it took approx. 17 minutes to request the surface quantity of the pavement. And every adjustment to the report definition takes a lot of time.
Regards, Nuttert
Hi Jan,
Indeed, during the install of ORD 2021 R2 (I used the Configuration option), no option to maintain R1 was found. After the installation however, R1 was still on my computer.
Another strange thing is that in the Windows Apps and Features list, OpenRoads 2021 R1 is not present.
After more test I decided to de-install ORD 2021 R2. The Reports function is much faster in R1. Here it takes a few seconds (still around 15) to view / create a Report. In the latest MicroStation CE version, this works right away.
I think Item types in combination with OpenRoads is a very strong combination. Hopefully a solution to the problem above is available soon.
Regards Louis
Regarding to the workspace, the problem also exist when No workspace is chosen (using the same dgn file).
Hoi Nuttert,
That's interesting. Are you using the VNMG workspace?
I did a test with the file while no workspace was chosen, the problem was the same.
