hi
Using ORD 2021 R2. When I created Terrain Model, neither its feature Definition not Name can be changed via Element Properties or within the Explorer. The only way is to do that via Pop-Up menu/context menu. Same with Linear Features, Meshes, etc. Name and Feature Definitions are faded-out.
is it a bug?
Adam
I saw this too - i think a ticket is in order...
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
I can change it in these two places 2002 R2. Out of the box settings except for the DOT configuration.
I have just seen this myself in 2021 R2 and I have logged it. It appears that if you use a 2D seed file to create your terrain from that creates the issue. I then added in my active terrain and set this active to create the 3D. I then ran create terrain from corridor meshes. I then couldn't rename it... If I used a 3D seed from the start I could.
I now have a defect number for this Defect 1142682:We can't change Terrain's Feature Definition and Feature Name from Properties Dialogue
Ross
Hi Ross, could it be dependent of whether you attach the Terrain into your 2d or 3d model in 2d/3d DGNs?
HI Mark
I was trying to rename it from the 3D model in the file I created the terrain no joy. As Adam says the only way to rename it is from the pop up menu that works..
