hi
Using ORD 2021 R2. When I created Terrain Model, neither its feature Definition not Name can be changed via Element Properties or within the Explorer. The only way is to do that via Pop-Up menu/context menu. Same with Linear Features, Meshes, etc. Name and Feature Definitions are faded-out.
is it a bug?
Adam
I have the same issue with hoizontal complext elements. Sometimes, element description is grayed out and cannot be changed!
I have this issue also in ORD 2022 R1, but only for terrains. I've been able to change linear template names and feature definitions.
Same, can't change Terrain names anywhere when working in 2022 R1. The models were created using a 2D seed.
I have this same issue on 2022 R3 so I guess it didn't get fixed...
Indeed... 2022 R3 (10.12.02.40) still has this issue. It has been a while since a release/ schema change, so hopefully some of these- and many other issues- will be ironed out.
Best Regards,
Mark
