ORD CE 2021 R2 - Cross sections - annotating slopes for non-template segments
Hi there,
With ORD, since the very begining of Connect Edition, I have had issues with annotating segment slopes on cross-sections.
Is possible to annotate slope between two points on cross sections that are not created with corridor template?
Time ago I was told it will be solved in 2021 R2, apparently it is not. I can not force software to annotate slope between points, eg from my site design. I tried listing Feature Definition, Point names, created dummy template in itl to chose template segments - no success.
Please advise how do you annotate slopes or distances between two points that are not orginated in the itl template.
Adam
  • There has always been an issue with slope annotation on the cross-sections. With ORD 2020 R2, I succeeded in annotating Cant and Wall Height as " point to point" vertical distance. With ORD 2021  and R2, such exercise was impossible, though the same annotation group. ( imported as XML). The slope of the segments has been an issue and remains with 2021 R1 and R2. I did a lot of tests but never succeeded. In General,  annotation of the cross-section remains unresolved with ORD AND ORLD. Furthermore, In 2021 R1 and 2021 R2, ghost elements are annotated.
  • Yes something that used to work: Defect 1142339:Xsection Annotation - Annotate user defined segment (not part of a template)
    Unfortunately workaround is not so quick. One way, I don't want to annotate each cross section, is to create a template with same number of segments we want to annotate and create point control to each point. Set corridor feature definition to not display component.
  • Can we expect a priority build for this? We were told it would be fixed with 2021R2 when logged SR for this defect months ago. Annotating slopes manually is a pain and for some of our layout creating corridor just to have slopes annotated is not an option.\
    Quite a basic functionality, I think.
    Adam
  • hi, just installed ORD 2021 R2 (refreshed) with some defect fixed. This slope annotations for segments is still not fixed.
    Is it on the road map at all? Not only I have to create template with segments but it also needs to be included in the top mesh. There is a number of scenarios whre we need to annotate distances and slopes between points that are not part of componts:
    -non-linear works (with no corridors being used for modelling)
    -slopes between point on the substructure (neither top nor bottom mesh) where pavement layers are not parallel - even for corridor modelling approach
    -distance from the right of way point/marker to the slopes extremity
    -distances between safety barrier and edge of traffic lane
    -distance between fencing and slopes
    -traffic lanes widths where full carriageway is not modelled (widdening scenarios, etc)
    -headroms
    etc.
  • Oh no, I thought 2021R2 fixed this? I’m sorry it didn’t, but I’m sure Bentley is working on some sort of a fix soon.
