I'm attempting to reference in a shapefile to an ORD file and it's not lining up correctly with my survey data. The first thing I did when I created the ORD file was set the GCS, but still having issues with the shapefile not referencing in correctly.
I opened the .dgn file in Microstation V8i and the shapefile and survey data appear to line up correctly.
Is there any kind of workaround so I can get the survey data and the shapefile to line up correctly in ORD?
Thanks!
UPDATE:
So, I created a new DGN file in PowerGEOPAK and added the shapefile and it aligns up with my survey data. I opened the file in OpenRoads and everything is still lined up. Not exactly sure why I can't create the file in OpenRoads to begin with, but that's the workaround I found that works.
It's a little difficult to narrow down your problem based on the information provided. But, if you are working on ProjectWise, note that the sister file(s) for the shapefile are not always loaded and you may need to export first. Not having the sister file(s) could result in incorrect projection of the data by ORD.
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
Zach McCormick said:That option isn't available when attaching the shapefile.
If you don't get the Geographic - Reprojected option that usually means that you don't have the corresponding .prj file that goes with the .shp file. In your case you should also have a Parcels.prj in the same folder as the Parcels.shp file.
When a Shapefile doesn't line up I usually attach a Bing Maps background, or open location Google Maps to verify the dgn data has the correct GCS and is in the correct spot. Either the dgn data, or the attached Shapefile should register correctly.
Based on that result you can better troubleshoot where the problem is.
Rod WingSenior Systems Analyst
Rod Wing said:If you don't get the Geographic - Reprojected option that usually means that you don't have the corresponding .prj file that goes with the .shp file.
It's exactly what I asked earlier, but unfortunately this information has not been shared yet.
Jan
Rod Wing said:In your case you should also have a Parcels.prj in the same folder as the Parcels.shp file.
I do have a Parcels.prj file in the same folder as the Parcels.shp file
Zach McCormick, EITSenior Transportation Design Engineer
Microstation V8i SS10 (08.11.09.919)PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer CE 2021 R2 (10.10.20.78)
Hi Jan,
Jan Šlegr said:To follow the best practices, can you specify the used ORD version (use e.g. "version" key-in to obtain product version).
I've updated the title of this question and some portions of my content to better follow the best practices.
Jan Šlegr said:Are you able to test the data in MicroStation CE (preferably in the latest CE Update 16.2)?
I was able to test the data in Microstation v8i (SELECTseries 10) Ver 08.11.09.919. The data lined up correctly in Microstation.
Jan Šlegr said:Has SHP file defined GCS or .prj file is missing?
I have a Parcels.prj file located in the same folder as the Parcels.shp file.
