When upgrading files to 2021 Release 1, we had labels in many drawings that were placed using Place Label from Cell that either disappeared or were moved well off of the items they were labeling. Is this common and is there a solution?
Hi JSchaffner
we've had a defect in OpenRoads Designer 10.10.01.03 version causing labels to shift to wrong locations when upgrading files from 10.09 to 10.10
This has been fixed in later builds and should work correctly in the latest release 2021 R2 (10.10.20.78):
softwaredownloads.bentley.com/.../2515
