I am trying to insert a curve into a complex alignment it inserted a vertex but no curve. Also cannot figure out how to delete the vertex
What version are you using and what command did you use... I think you may have not used this command under vertical geometry tools.. The command is called "Profile insert vertical curve" . This command once you insert the vertex will then prompt you for the vertical curve parameter. In your case when you don't have a vertical curve, to remove the vertex use the standard microstation command delete vertex.
Ross
Answer Verified By: Jeffrey Rudy
