I've read all the previous posts on the subject, but still I can't get side slope annotation to work. I've created 3D feature lines, and used the "create 3D by slope to target" function to create my earthworks extents. What I'd like to do is show the slopes with tadpoles, but I can't get any annotation to work. I've created side slope annotation which should be looking for the feature "Limit of CutFill Slope":
My earthworks extent is defined as this feature:
Next, I'd like to have the annotation from my hinge feature:
I've applied the annotation group to the feature symbology:
When I try and annotate my model nothing appears for side slope annotation, at all. I've even tried it with just simple lines and it still doesn't work. Am I missing a crucial step somewhere?
Hi Greg
Last time I checked, Tadpole cells don't work with slope annotations, to get these to even remotely work in ORD you have to create a custom line style with the tadpole cell. I'll dig out the guidance from Bentley on this.
But I would check out the Last Mile Tool which Bentley have created, it has a slope annotation feature.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Hi Warren,
I believe the side slope annotation engine was completely revamped in 2021 R1, now also works with Linear Templates and Civil Cells and looks to work exponentially faster and better now. I believe the issue as to why this function is much heaver than c3ds is that it is dynamically linked to the corridor (so will update on process) and also annotates in 3d - 2 things i dont recall c3d can do (its been a while so things may have changed). That being said, still more work needed...
Greg, I dont believe there is any way to annotate between linear features as the native side slope annotation is based on corridor-based workflows. The only way to get this to work is to apply a linear template, but it defeats the whole point of your workflow.
Mark
Thanks Mark
I set aside my pessimism and tried it again in 2021 R2 and, for the first time ever, I've gotten slope signatures to work!
Hi MaryB, Please see the IndiaLastMile tools with recorded videos how to install this ontop app and to annotate side slopes for 2D and 3D elements: Last Mile Utilities - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities. Regards Matthias
