Using 2021 R2
I have been creating new Sheet dgnlibs to deal with certain issues we are facing. When I create the Plan and/or Profiles, the Sheet Annotation is coming in a fraction of the size it should. I am using a 1"=40' scale.
The Plan and Profile borders are coming in at 100' length, for a 1200' plan/profile.
Any thoughts/suggestions? Happy to share the files.
Probably a silly question, but are all of your files using the same working unit definitions and unit resolutions?
MaryB
Yes.
I had to generate all new files as we are utilizing International Feet instead of Survey Feet...
I am guessing it is some setting like that, but I am at a loss at the moment...
Another probably silly question, but when you say 1"=40' do you mean 1:480 or 1:40? In past workspaces in Microstation/InRoads, we'd set everything to 1:40 for 1"=40'. It was never a problem; we all knew that it wasn't really 1:40. In ORD, someone apparently decided that they absolutely had to change that and make it 1:480 - so everything that we had from old workspaces (borders, text styles, line styles, cells, etc) is now off by a factor of 12! Super annoying. Your screenshot looks almost like a factor of 12.
Hi Dan - did you ever figure this out? I'm having some issues with Profiles coming in wonky too and I'm guessing you've mastered this by now
I did solve this... It has been too long and I don't remember the solution to the issue I was having.
Since this was so early in the development, it was probably a scale thing (as discussed below)
If you post the file, I can take a look.
-Dan
