Photos to illustrate issue only. I'm having an issue when I move, or modify a survey point in any fashion (change field code, shift XY location, etc), the SURVPN-CROSS (point locator) vanishes and does not visually return if file is closed and re-opened. The point still exists in my survey explorer, but with no graphical node, I cannot use the point anymore (IE: connect other survey chains to it, etc.) Is this a settings issue, or just a glitch. Any input welcome, as it's essentially halting all production.
Thanks for the feedback. I was having the issue with no refs attached. Had to have a coworker open the dgn and redraw so I could keep working. Having an issue with refs will certainly cause a lot of issues if it's not resolved.
Take care,
Cliff
I have several tickets with Bentley.
Personally I think Cliff Mennenger is more helpful than Bentley.
Thank you
