How to adjust ground elevation or rim elevation of drainage structure? This option is grayed out and have looked under utility properties but no option to enable it. Does anyone have any idea?
Your structure is ruled to "Proposed Terrain Merged" as the Elevation Reference. If you want to adjust it manually you'll need to remove the elevation reference from the node.
That's exactly what I wanted to do, adjust it manually. Thank you.
You can also leave the structure ruled to the Proposed Terrain Merged, and use the Vertical Offset property to adjust the Ground Elevation relative to the terrain model. For example, typing a value of -0.1 would make the node's ground elevation 0.1 feet lower than the terrain.
I tried your suggestion by entering -0.1 to the vertical offset but the software couldn't process the adjustment somehow. The software always closes after each attempt and I tried this with various offset value several times.
That obviously shouldn't happen. It sounds like it may be data specific - the software appears to be having trouble reading the elevation reference.
If you can, please raise a Service Request, with your data, and we can look into it for you. Please note the version number of the software.
Thanks.
