Is there any way to import analysis results from HECRAS into Power Civil? HECRAS can export to SDF format (spatial delimited file) but I can find no tools to import SDF into Power Civil. I want to show the water surface results in my DGN.
Power Civil v8i
Neil,
I'm sure there is another solution somewhere.
If not, following my solution and Loading the DTM Hull should give you the outline of the floodway.
Michael
