Separate object in corridor
Is it possible to separate each element in one corridor using one, the same template? I have for example 2 the same tunnels in one corridor, and I want to have them independent.
I tried to use split mesh but using this function I can't export that to even basic IFC file. Export to IFC is neccessary. I' m looking for complex solve this problem. I know, if I have only two objects I could give them two different feature definitions, but how about 30?
Best regards
Andrzej
