Delta Station in Profile View
I'm wanting to create a line between points in profile to represent junction visibility and so I use Civil Accudraw to set the offset above a point projected from the sideroad centreline (dZ option) and then I want to set the height at the end of the line above a profile I've projected from a terrain so I used the ProfileOffset option. All works great except when I change the length of the horizontal, the second point of the vertical line is still at the same station as before and not the new end station for the horizontal.
How can I link the end of the vertical to the end of the horizontal? In particular while setting an offset from a profile at that location? Is there a way to have delta station in profile just like in plan?
Also I've noticed it's not possible to edit favourites for the profile set of Civil Accudraw options?
Feel like this should be simple but just can't seem to figure it out.
Ken
Parents Reply Children
