InRoads MCMTB is already loaded
I am not a programmer, just an user of InRoads SS10. I'm trying to create cross sections along an alignment. I loaded the DTM and ALG files, but it doesn't show anything, giving me this message: " MCMTB is already loaded". I looked for some help in this Bentley communities to see if anybody else has had the same problem, I found out this comment:
I tested your MVBA code in my PW V8iSS4+MstnV8iSS3Update1, the message center was really blocked to display anything.
For the Chris's suggestion, you should test as below in MVBA:
SetCExpressionValue "tcb->control.inh_err", 0
SetCExpressionValue "tcb->control.inh_msg", 0
I don't know what is it mean and where should I change it?
Thank you,
Lucilia
