Why can't ORD Process Survey Points
To say that I hate this Software is an understatement, everytime we try processing survey data we get some issue, I am sick of it. My issue now is I have survey points that I have imported already and now that I am trying to add a new file, but when I do it stops recognizing the feature definitions which it already had in previous recognize deleting all the linework that was created before. and leaving me with a lot of error cells. Had anyone had a similar situation or had any luck processing survey points with OpenRoads Disaster?
  • Lots of quirky problems for sure. I had a similar issue on a large project using 10.8 a couple of years ago.
    Version?
    Survey file format? (stay away from sqlite)
    How many points in the survey data file?
    How many points are already in the database?
    Do you have shared cells in the dgn file?
    Have you tried...
    Redraw?
    Compressing the dgn deleting empty cell headers?
    Delete the feature definitions from the dgn and rebuild from the LIB file?
    Is it failing on all points or is it certain feature codes?
    Take care,
    Cliff
