ORD 2021 R2 - error stacking cross sections on sheet
Hi
For a longer time I've been struggling with stacking cross-sections on sheets. Basically only a single sheet is created with a single cross section displayed. However all other references are attached.
The X/Y  of reference attachment origin is set to: -nan(ind). I am using no Coordinate Systems in the master model for cross sections, however there is one set in the model with Centerline, corridor and terrain.
This happens most of the times I am trying to create sheets. Drawing models are just fine.
What may be the reason for this?
