I'd like to annotate the manholes according to this example:
The first 2 lines are possible to do,
The last 2 lines I'd like to have the levels of the connecting conduits and the feature name it is connected to. In that case it is clear to seen in top view what the several elevations are.
The text favorite looks like this:
Yes - please create a SR for this issue. I have looked into recently, and I can't find a neat way to do this at the moment. What I think we need is to be able to create a text favorite with a conditional statement, so that it can test whether a value is valid before it tries to annotate it.
I have reported and it will be adjusted in a next version.
Sorry to revive an old thread. Has the ability to create conditional labels been implemented? I would like to create node labels like Gunther but am not seeing a way to filter out the connections that do not exist.
I haven't tested it, but it should be fixed in the new release (2022 release 1).
I'm with you. We need conditional labels for other things as well. We are keeping some of our Survey settings to use VBA labels instead of "regular" labels because we can code our own conditions. But these labels only work with Survey and only fire off when specific actions occur in the survey file. You cannot attach them to a button and simply click on an object to label.
