Hello-
I am experiencing weirdness with my alignment/profile in OpenRoads Designer 2021 R1.
I have a 3 mile trail with many horizontal and vertical curves. I know there may have been limitations with Geopak/V8i with the number of vertices in a profile, but was hoping it wasn't in ORD. In the 3D view, there is a chord shown through a section of my alignment. I have deleted .upf and deleted the 10.0 folders in efforts to fix, but it hasn't. I have tried a couple of times and the last time there was a large gap in my 3D view instead of a chord, and not in the same station range.
Does anyone know if it is due to the number of horizontal and/or vertical PI's in this alignment and profile?
Thanks for any insight.
Hi Katie,
I assume your data was imported? Maybe one of these variables may help?
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Thanks, Mark. It was not imported. Fresh from seed ORD file. But I am interested in the top two variables there you mentioned. It sure seems like a problem with the number of elements. With trails, one will always have lots of elements due to the circuitous nature of them. I'll see if those variables make any difference, thank you.
Hello, did you find any solution for this issue ? I'm facing the same problem.
Regrads,
