CONNECTION Client offered me today upgrade from ORD 10.10.20.78 to the latest 10.10.21.04.
Why this minor upgrade for released and what new changes or fixes it offers?
With regards,
Jan
This also resolves an issue with IFC 4 exports failing for large models and GENIO exports failing to export 3d features with voids/gaps in them.
Mark
Hi Mark, it seems that IFC export for larger model with added items is still not working:-(... I do not know how to solve this issue... i can do that export only throught iModels and ProjectWise365 portal
Do you need to use Named Boundaries to split the export to IFC?
No I did not use named boundaries for export. But I will refer with my SR to yours
Thank you Jiří B.
To confirm, have you installed the updated 2021 R2, ie. 10.10.21.04?
Hi Mark, yes I have mentioned version
Hi I placed SR and I got nr 7001391658
