Changes in the newest minor update 10.10.21.04?
CONNECTION Client offered me today upgrade from ORD 10.10.20.78 to the latest 10.10.21.04.
Why this minor upgrade for released and what new changes or fixes it offers?
With regards,
  Jan
  • Not yet, because until today´s morning I search for mistake at my side. I put a lot of effords to find what I did wrong... But I did not find any problems. So I will send a service request.... Or are you willing to make some test with my model file which originaly comes from OBrM?
    Thanks and BR Jiří
  • Defect 1142330:Large Model cannot finish IFC export process
    Defect 1142329:3D LINEAR FEATURES WITH VOIDS NO LONGER EXPORT TO GENIO
    Defect 1142331:XS Annotation will annotate elements that are invisible due to display rules/corridor clipping
    Mark
    OpenRoads Designer 2023  |  Microstation 2023.1  |  ProjectWise 2023
  • Some outstanding issues are that the new IFC 2x3 is incomplete (ie. does not correctly complete IFC schema for models to be displayed in any BIM viewer) and IFC export using Named Boundaries gets an exception error for large models.
    We also have an issue (back to 2021 R1) where large IFC exports with Item Types use up to 100Gb of RAM to export large models (we have special machines for this), however this seems to have gotten higher the latest release  - is this the issue you have?
    Mark
  • Hi Mark, yes it seems that you have similar problem with IFC export as I have - please check latest export log which ORD did
    Exception caught in source file e:\builds\cif10102104\Source\Cif\src\managed\ui\tools\PrimitiveCommand\PrimitiveCommand.cs at method OnDataButtonInternal
    Inner Exception : Input string was not in a correct format.
    In Assembly : mscorlib
    Stack Trace :
       at System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt)
       at Bentley.ECObjects.ECObjects.StringToDouble(String value)
    Exception : Can't convert from 'String' to 'Double'
    In Assembly : Bentley.ECObjects3
    Stack Trace :
       at Bentley.Civil.RoadwayDesigner.Commands.ExportIfc.AddPropertyIfcWithUnit(PropertySetIfc ps, String propertyName, CustomProperty customProperty, IECPropertyValue propVal)
       at Bentley.Civil.RoadwayDesigner.Commands.ExportIfc.CustomPropertyToPropertyIfc(IDgnECInstance instance, PropertySetIfc ps, CustomProperty customProperty, IECPropertyValue propVal, String name)
       at Bentley.Civil.RoadwayDesigner.Commands.ExportIfc.ItemTypeToIfcPropertySet(ItemType itemType, IDgnECInstance instance)
       at Bentley.Civil.RoadwayDesigner.Commands.ExportIfc.AddItemTypesProperties(List`1 properties, Element element, DgnFile dgnFile)
       at Bentley.Civil.RoadwayDesigner.Commands.ExportIfc.AddIfcProperties(Corridor corridor, CorridorSurface surface, MeshElement meshEle, Double surfaceStartStation, Double surfaceEndStation, DgnFile dgnFile)
       at Bentley.Civil.RoadwayDesigner.Commands.ExportIfc.GetAllMeshes(List`1 models)
       at Bentley.Civil.RoadwayDesigner.Commands.ExportIfc.FinishCommand(DgnModelRef dgnModel)
       at Bentley.Civil.RoadwayDesigner.Commands.QuantitiesReport.MoveToNextState(QuantitiesReport command)
       at Bentley.CifNET.UI.Tools.ParameterEntryState`2.Entered()
       at Bentley.CifNET.UI.Tools.ParameterEntryState`2.InternalPrimitiveParameterState.OnParameterAccepted(AcceptMethod acceptMethod, Object parameterValue)
       at Bentley.CifNET.UI.Tools.ParameterState.DoParameterAccepted(AcceptMethod acceptMethod, Object parameterValue)
       at Bentley.CifNET.UI.Tools.CursorPrompt.ParameterPromptManager.PromptDialogManagerOnDialogResult(Object sender, DialogResultEventArgs e)
       at Bentley.CifNET.UI.Tools.CursorPrompt.PromptDialogManager.SetResult(Object value, AcceptMethod acceptMethod)
       at Bentley.CifNET.UI.Tools.CursorPrompt.ParameterPromptManager.Bentley.CifNET.UI.Tools.ICommandParameterPrompter.OnDataPoint(IButtonEvent pointEvent)
       at Bentley.CifNET.UI.Tools.PrimitiveCommand.<>c__DisplayClass107_0.<OnDataButtonInternal>b__0()
       at Bentley.CifNET.UI.Tools.PrimitiveCommand.ManagedBooleanCallBack(Func`1 method, Boolean exitCommandAndCleanupCaches, Boolean retValue, String message, String memberName, String sourceFilePath, Int32 sourceLineNumber)
  • yep, that looks to be the same Named Boundary IFC export problem. I put in Service Request: 7001378219 but the support engineer hasn't been able to reproduce it yet because his test models are too small - i suggest you put a ticket in to get it resolved...
    Mark
