I am looking to print plan over plan roadway sheets with aerials on, but even when everything appears okay in ORD, the PDF comes in with the bottom aerial slightly darker along with grid lines showing. Top aerial is fine and prints properly.
I have tried updating sequences of my references, using bing maps as a raster rather than FDOT aerial raster images, and manually referencing the aerial into each drawing model rather than the default. Still getting the same issue each time.
Any help would be appreciated! Thanks.
Just ran into this exact same issue. Haven't found a solution but maybe my comment will boost this thread.
Have you found a solution? I am having the exact same issue. Thanks!
If the aerial reference file is moved or scaled from the original coordinates and a 3d file is attached to the plotted file the aerial will plot with grid lines.
Something to due with rendering a 3d file that has been moved. The solution is to remove the 3d file.
Zane Pratt
Civil Designer
Zane is absolutely correct here. I have experienced this issue personally.
Mark
