Dear all,
Could someone help to show me the regulation relating to line weight in Microstation and OpenRoad Designer?
Differ with Autocad, line weight in Microstation showing number 0, 1, 2, 3, ... and I don't know the correct thickness.
For example, line weight 1=?mm, ...., and which regulation for this in USA or Euro?
Thank you in advance
Hi Hoàng Tuấn
Each of the 32 possible values of element line weight can be set to display with any width you want. Display widths are measured in pixels (screen dots)
See more about how the set the display widths here:
docs.bentley.com/.../GUID-F79DDCED-59DB-23AC-99A4-515A831D4F2B.html
Answer Verified By: Tuan
You can define the exact print width of each line weight in the pen table, among other places.
Here's a good discussion: Line weight configuration for printing. - Printing and Plotting Forum - Printing and Plotting - Bentley Communities
As mentioned above, exact line thickness is defined at print time with a pen table, design script, or pltcfg file.
If using the defaults, a place to get a general sense of corresponding thickness is to look at the line weight mapping in the DWG save options.
Rod WingSenior Systems Analyst
