Hy,
I created some textstyles In the dgnlib File, that alredy existed, under C:\ProgramData\Bentley\OpenRoads Designer CE 10.10\Configuration\Organization-Civil\My-Workset\Dgnlib\Feature Definitions. I created this workspace and workset by copying everything from the workspace Metric Standards. So the specific File was not created by me it's a copy of the one in _Civil Default Standards - Metric.
Anyway, When I open up another file with that workspace and workset active the new textstyles do not show up. As if they don't exist. The only difference I see between the alredy existing textstyles and my textstyles is that my textstyles dont have the green checkmark, is that wy it's not working?Or is there another reason?
How can I change that, so that I can use my textstiles?
It seams to be designed to look at the originals...
How can I change that? I want it to look at the copies...
You will need to edit the configuration files for your new workspace so that your variables point to the directories and files in the new workspace instead of the old.
Is your workspace located on a network, used by other coworkers? or is this something on your computer alone? If you've created a network workspace, you need to be careful editing variables, because your changes will affect everyone using it. If it is local, you won't mess anything up for anyone else. But you should still be careful, and research all your variables. Many variables use paths defined by other variables, and it can be very easy to edit something and create unexpected results.
There is an entire forum dedicated to workspace administration. While most of the posts do not address ORD specifically, the general information applies.
MaryB
I'm gona look at it tomorow and see if it works.
It's only a local Worckspace I created to test and learn. So that I don't brake anything, when I start working on "real" workspaces.
