Good morning. I am starting to test the sheet creation tools in ORD Release 3 for the first time. The current configuration from PennDOT automatically inserts a border into the sheet models as they are created from the named boundaries. However, we will need this border to be a project specific border file that contains the correct information in the title block rather than having to go into each sheet model and edit the title block info. How would I accomplish this?? I would imagine I need to place a copy of their border seed in the project workset folder somewhere and edit the tittle block as needed, but how would I need to adjust the configuration to select this project specific border file?? Thanks.
Brett
Hello again, I can only speak from my experience, but if things are already being pulled from a workspace/workset you may not need to get into the configuration. Personally, I rely on workset files to preserve the configuration of my DOT's workspace and when on ProjectWise.
The sheet seeds that control the settings for creating a drawing/sheet model are in the workspace's Dgnlib/Sheet Seeds folder, not the main Seed folder. I'm guessing that the current blank border dgn may just already be attached directly to those.
I would try copying the desired sheet seed dgnlib (my DOT provides options at different scales) to the same location or to your workset standards location, opening it and replacing the border reference with your edited copy. Rename the models/view/boundary to show that it's for your project. Then when you create a named boundary/sheet, select that new drawing seed, the sheet created will have your project border already referenced in.
Let me know if this make sense!
I agree, but this requires the definition of the config variables I noted above within the WorkSet's .cfg files as well, right?
It sounds like a matter of personal/company preference and there are options here. I just personally have warmed up to the idea of letting the DGNWS control.
Neither option is perfect and each has its drawbacks. Either way, I'd say pick whichever you like best and develop a workflow internally that your users can follow easily as they will often default to path of least resistance :)
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
I'll also add to this great information Eddie, I found out recently you can open a DGNWS file as any dgn or dgnlib file and edit properties which could make initial setup easy (curious if doing this causes any issues??). Another note on the dgnlib method is that the more dgnlibs the workspace loads the slower things take to process as mentioned on a recent webcast by Chuck Lawson. Here's that link to register/view for those here... https://event.on24.com/wcc/r/3699890/D3F080986E63FA49DB5B5F9A45033F36?mode=login
colliersengineering.com
Does the dgnws and workset properties work in Projectwise? I have heard there are issues with this in Projectwise.
Zane Pratt
Civil Designer
