Setting up all my fields to pull data from the sheet index, but it doesn't appear to be possible to have it auto populate the scale as the scale of the sheets are always 1:1. Guessing it is something I have to hard code into all my sheets and have different ones for different scales?
ORD 2021 R1 10.16.088
Hi Peter, you can set this up in your Sheet Seed. Just add a field in your Sheet using the Drawing Boundary marker as the element and you can get the scale value of the Drawing model reference. It works well for us. The only annoying thing is that there doesnt seem to be a way to get the Vertical exaggeration value for Profiles - somebody correct me if im wrong...
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
