I have been facing a problem with super elevation for some months now.
The Alignment , corridor and superelevation are in different files. More often, the corridor file does not reflect the super elevation. The point control window in Corridor objects show the Superelevation controls, the dynamic cross section show the magenta points for superelevation, but the corridor lanes does not get rotated for the superelevation values.
The issue gets sorted out randomly, some times closing and reopening the files, reattach corridor, reattach reference, reapply superelevation. There is no particular way. But it gets sorted out on any of the mentioned actions. Sometimes it does not get sorted at all.
This is consuming a huge un productive time. Please help me if anyone has a solution for the problem. This problem was faced by other members in the team too.
I am using OpenRoads Designer CONNECT Edition - 2020 Release 2 integrated with projectwise.
Hi Ramanan R
You posted your question in the Licensing, Cloud and Web Services discussion and you may not get any answer to your question here. I am moving your post to the OpenRoads forum.
thank you.
Do you have the superelevation flag checked in the template library?
Jennifer Perry
Highway Design | Johnson, Mirmiran & Thompson, Inc.
I have had this same frustrating issue. As you said, it will normally work itself out. Most of the time reprocessing the corridor will do the trick for me. I am not sure what the root problem is but seems to be a bug.
Yes, the superelevation flag is checked in the template for the relevant points
