I have been facing a problem with super elevation for some months now.
The Alignment , corridor and superelevation are in different files. More often, the corridor file does not reflect the super elevation. The point control window in Corridor objects show the Superelevation controls, the dynamic cross section show the magenta points for superelevation, but the corridor lanes does not get rotated for the superelevation values.
The issue gets sorted out randomly, some times closing and reopening the files, reattach corridor, reattach reference, reapply superelevation. There is no particular way. But it gets sorted out on any of the mentioned actions. Sometimes it does not get sorted at all.
This is consuming a huge un productive time. Please help me if anyone has a solution for the problem. This problem was faced by other members in the team too.
I am using OpenRoads Designer CONNECT Edition - 2020 Release 2 integrated with projectwise.
Did you recently make a change to the horizontal alignment? If so, make sure to open and close the super dgn. I have come across where the super will disconnect if that file is not opened after updating the alignment.
Jennifer Perry
Highway Design | Johnson, Mirmiran & Thompson, Inc.
Thank You. It worked.
