I am piloting a project in ORD and I am unable to create a corridor model with referenced alignment and profile geometry. A corridor and template drop are created, but they appear with no content. If the alignment and profile geometry are located in the model file, a model is created.
I have successfully followed this workflow in SS10. This workflow is outlined in the ORD support videos. Are additional steps or settings required for this to work in ORD?
OpenRoads Designer CE - 2021 Release 1 Update 10
ProjectWise Explorer CONNECT Edition Version 10.00.03.434
The workflow is the same in 2021 R1 as in earlier versions. Are you sure your Corridor DGN file started with a 2D seed? And that the Geometry is attached to the 2D model?
Thanks for the response Joe. Yes, the corridor file was started with a 2D seed, the attached geometry was created from a 2D seed, and the corridor model was generated in the default 2D model. The issue appears to be with the referenced geometry. The corridor model is created when the geometry is in the corridor model file.
Sounds like you've done everything right from a workflow standpoint. When the corridor is created when "the geometry is in the corridor model file", are you recreating the geometry? Importing it from another file? or maybe merging files? In other words, how is the geometry getting into the corridor model file?Another thought, any chance the "referenced geometry" was created in an earlier version of the software and not directly opened in your current version (ORD 2021 R1)? That could be an issue, just remember, once it's opened in a newer version it can't go back to an older version.
Ensure that the profile is set active in your geometry file. And ensure that you have an active terrain in your corridor file. To me, when the corridor is appearing with no content, one of these would likely be the issue.
Answer Verified By: Patrick A.
While creating the corridor model have you created template drop as well. Can you please confirm if you have selected the the template drop, Start and End station, Drop Interval etc.
If you have just created the corridor and not applied the template, in that case please select the "New Template Drop" tool and create the corridor model.
Please refer following video about creating Corridors in OpenRoads Designer.
www.youtube.com/watch
