I am piloting a project in ORD and I am unable to create a corridor model with referenced alignment and profile geometry. A corridor and template drop are created, but they appear with no content. If the alignment and profile geometry are located in the model file, a model is created.
I have successfully followed this workflow in SS10. This workflow is outlined in the ORD support videos. Are additional steps or settings required for this to work in ORD?
OpenRoads Designer CE - 2021 Release 1 Update 10
ProjectWise Explorer CONNECT Edition Version 10.00.03.434
Thanks Matt - I went into the geometry file, removed the active profiles, and re-established them. When I opened the model file, the models reprocessed and appeared. I am not sure what the issue was, but that worked.
Joe - I able to fix my issue by re-establishing the active profiles in the geometry file. Thanks for your help!
Thanks Abhilash - There was an issue with the active profiles in the geometry file. I re-established the active profiles and that solved the issue.
